After market
Old Nov 12, 2003 | 03:09 AM
showtime22's Avatar
showtime22
Default After market
i have a 95 neon and bought a 3 3/8 tach with shift light and i cant seem to figure out what wire to hook the tachwire up to, toreadthe rpms. ive called the factory and they told me some wires it would be and they didnt work... does anybody have any suggestions, or hasanybody hooked up an aftermarket tach if so can u tell me the color of the wire u hookedit up to and where it is located</P>
THANKS</P>
Old Nov 12, 2003 | 04:45 AM
71RoadRunner's Avatar
71RoadRunner
It may require an adapter. I plan to add an Auto Meter 5" tach w/shift light, but when I do this I will also be adding an MSD Dis-2 ignition which makes the tach hook-up easy. Check MSD's website for the adapter and wiring diagram: www.msdignition.com<edited><editID>71ROADRUNNER</editID><editDate>37937.0745023148</editDate></edited>
Old Nov 12, 2003 | 11:42 AM
showtime22's Avatar
showtime22
it will be easy for u because you just hook yoursright up to the coil because it is an older car i believe. but thanks for the info ill give it a try today.
