wich plug do i use on coil?
I had my 2000 neon engine apart for a head gasget change. Now i'm not sure what wires go to the coil. The sensor on the front of the block uses the same connector and reaches to the coil. Maybe I mixed them up, thats why my car wont run. Could some one please tell me the colors of the wires that go to the coil pack?
I know that the coil plug will be for 3 flat pins. Check to see if they are different, if you cannot tell then try plugging each one into the coil, hopefully only the right one will fit.[sm=smiley2.gif]
Well that sucks. Mine is a different year and they may have changed the wiring color or I could check mine for you. I'll check it anyway and let you know what mine are.
