rubber oil drain plug
Old May 10, 2006 | 04:39 PM
brianh's Avatar
brianh
Default rubber oil drain plug
Anyone have any experience using a rubber oil drain plug? I had to put one on the other day after my pan stripped out on my 99 neon. I used the kind that has a wingnut on the end of bolt and a big rubber plug at the end. Just wondering how long this will last me until I can either re-tap the pan or buy a new pan.
Thanks.
Old May 10, 2006 | 04:45 PM
casper's Avatar
casper
Default RE: rubber oil drain plug
I would replace the pan. I am sure they work, but I would not trust a rubber plug.
Old May 11, 2006 | 12:39 AM
ewetho's Avatar
ewetho
Have seen them they work in a pinch but just get a pad not that expensive and with some regular hand tools and front end on jack stands you can change it yourself. Not that hard.
Old May 11, 2006 | 02:27 AM
brianh's Avatar
brianh
Thanks for the responses. Just purchased this pan today http://www.1aauto.com/1A/OilPan/Dodg...crn=&ovtac=CMP
Hope the rubber plug holds up until it gets here.
