1995 Radiator fan not woking
Old May 10, 2006 | 06:34 PM
lwpatent's Avatar
lwpatent
Default 1995 Radiator fan not woking
I have verified relay is ok.
fans do work and spin freely.
have verified that no power is getting to fans.
I am wanting to look at the wiring ant the temperature sensor next, but have no idea
where to look.
I have A/C ( hence the double fans, if theat matters. )
THanx!
Old May 15, 2006 | 06:54 AM
cam67's Avatar
cam67
Default RE: 1995 Radiator fan not woking
there r three Sensor one one the fan case on the bottom and one next to the rad cap on the intake manifold and one under the battery case on the fame. hope the helps u out [sm=signs003.gif]
Old May 15, 2006 | 08:27 AM
RadarLove's Avatar
RadarLove
Have you verified power to the relay? Fuse isn't blown?
There's only one coolant temp sensor. On the DOHC, it's next to the thermostat on the intake manifold. On the SOHC, it's on the back side of the head. I may have posted resistance readings in an earlier post. If not, I can pull them out of the FSM again for you.
My '95 came with a/c from the factory, and only one fan...
Best of luck!
