rpm gauge install
Old May 20, 2006 | 10:42 AM
neonred's Avatar
neonred
Default rpm gauge install
hello new member here,
i was wondering how to install a rpm gauge.
Old May 20, 2006 | 02:59 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: rpm gauge install
were you planning on putting in the instrument cluster with a tach or just installing an aftermarket tach?
i had an aftermarket in my 01, but honestly dont remember the install
youll tap into a wire off the coil... but dang if i can remember which one i believe it was blue wire... i even had a tach in my 01, so aggravating.
Old May 20, 2006 | 05:51 PM
neonred's Avatar
neonred
i want to put in the othere gauge cluster but i dont know if the wires are there, so im thinking aftermarket.
Old May 20, 2006 | 10:09 PM
Ramrat's Avatar
Ramrat
clusters are a direct swap, all the wireing is there. i did it in my 96 and the only thing was the odometer was about 25k higher on the cluster i put in but the old one was dead anyway so for all i know it might be right lol
Old May 21, 2006 | 01:16 AM
neonred's Avatar
neonred
thats cool i might just do that, cuz i just put a new motor in 2 weekends ago.
Old Jun 21, 2011 | 09:43 PM
airstal870's Avatar
airstal870
NEONRED : where you able to put in a new cluster with an integrated rpm gauge on your neon?
I have an 02 neon and was looking into putting in a cluster with an integrated rpm gauge is it a perfect fit are all wires already there or do adjustments need to be made?
