fog lights
(2nd generation)
had a direct link i saved in my email to the how-to:
http://users.rcn.com/hsd/SRT4Fog/index.html
personally, I find this method very questionable, very tedious. I myself would just wire them as daytime running lights with a kill switch mounted into the carpet next to the driver's seat. If you do choose to use this method mentioned above for wiring the switch, I would go to a junk yard and get an old multiswitch to mess with... just incase you jack it up
edit: only other way is that i heard on a forum, i think it was on srtforums.com somewhere, that the jeep liberty and/or pt cruiser uses an almost identical multi-switch as the 2nd gen neons and it will fit right in. its a much easier bypass than chopping apart your current multi-switch. you could also try looking at the wiring diagram for the headlight relays and snip-n-crimp it that way.
edit again:
I found the discussion on srtforums.com!
http://www.srtforums.com/forums/showthread.php?t=38935
edit again:
Get driving lights.
Driving lights are for use with high beams, Fog lights with low beams.
But if ya have too, twoo options, wire them drirectly off a switch with no sensing circuit, or replaceing sensing circuit to the other beam.
