Vacuum Hose Leak
Old Jun 6, 2006 | 04:41 PM
nippondrifterae111's Avatar
nippondrifterae111
Default Vacuum Hose Leak
Just need to know how to find a vacuum hose leak cause my car is throwing that engine code. Arigato Gozaimasu!
Old Jun 7, 2006 | 07:25 AM
bouda's Avatar
bouda
Default RE: Vacuum Hose Leak
Listen for a whistleing/sucking sound under your hood. Look for cracked or disconnected small rubber hose. Spray some carb cleaner at any suspected sites(while it's running), if there is a change in rpm's you've found something.
Old Jun 7, 2006 | 10:22 PM
ewetho's Avatar
ewetho
Another way to find is to use an "UNLIT" propane torch to give litte extra fuel to enrichen the mix. Change in RPM. Check one hose at a time. Also chack the mating surfaces of the intake manifold as well.
