blinker
Old Jul 25, 2006 | 04:06 AM
cadb69422's Avatar
cadb69422
Default blinker
Allright i just bought a 98 dodge neon noticed that when you turn on the blinker it dont clik off like its suppose to. Is there a switch in the steering column or a pin or something that makes that turn off when you turn the wheel. and how do you fix it.
Old Jul 26, 2006 | 02:18 PM
das2123's Avatar
das2123
Default RE: blinker
There is a little actuator that is getting stuck or broke. I got a used one at a junkyard for $9 and just replaced it. Remove 3 screws from the bottom of the shroud and then pull the top part off. Remove the 1 retaning screw for the multi-function switch and replace.
Old Jul 26, 2006 | 04:41 PM
cadb69422's Avatar
cadb69422
Default RE: blinker
cool ill have to rip the steering column apart and check it out.
