how to- door panal removal?
Old Aug 21, 2006 | 03:47 AM
Jaime340's Avatar
Jaime340
Default how to- door panal removal?
well dose anyone know how to remove a door panel? from a 2005 neon sxt. also if i wanted to use the stock stereo were do i get a remote wire to install an amp? thanx
Old Aug 21, 2006 | 07:59 PM
04r/t_11's Avatar
04r/t_11
Default RE: how to- door panal removal?
Unscrew the three (or 4?) screws, then pull....well used a flathead and go around the edge of the panel and pop (genly) the tabs that secure it in, the lift up and away to take it off. Be careful of the wires if you have pwr anything. They disconnect though.
Old Aug 22, 2006 | 02:26 AM
Jaime340's Avatar
Jaime340
do you happen to know the speaker size of the door pannel?
Old Aug 23, 2006 | 04:05 PM
fraggle_a's Avatar
fraggle_a
The remote.....
Good question.
I used to just run a single speeker wire back to it with the power wire. Hooking the remote to the 'power' for the radio. Be caurful though, make sure its the power and not the illumination or aux wires! LOL......
Depends on where your going to put the Amp, and where its getting its power from?.
Thinking quickly.
Id mount my Amp in the rear, Ill have to run a good length of wire from the battery to it. The remote though, I would probably see if I can hook into the fure box somewhere, find the accessory circut and draw from there and run the wire along with the power through the car. Theres plety of space under the trim to hide the wires....
Old Aug 24, 2006 | 07:46 PM
djmagic's Avatar
djmagic
pop off the little triangle piece, and then get the screws out and make sure you get the one underneath the door handle, on the amp, mount it on the back part of the back seats
Old Aug 24, 2006 | 08:58 PM
QBall02's Avatar
QBall02
You need an aftermarket HU to run a remote turn-on wire to it. You might be able to find something that acts the same somewhere in your fuse box, but you won't find one on your stock head unit.
Stock speaker size for the doors is 6.5"
