a little help?
okay, here's the deal: i just got xenon foglights in the mail to match my xenon headlights i've already installed. cool, huh? well anyways, my problem is there's nothing in the manual about changing foglights, and i can't seem to figure it out on my own. i know some of you guys have already replaced yours, so... HELP!!! please.
okay, heres how you do it or at least how I did it. There is a splash shield that is in the way blocking access to the foglights. So you need to take that off which is easy, its held up by screws or by those plastic fascia screws (the ones that basically just push in and hold, I can't remember which it is because I changed mine out so long ago). Then you should be able to get at the foglights from the back. There is not much room at all, it is really tight quarters, I hope you have small hands that fit in there. Other than taking that splash shield off thats about all there is too it. The lights twist out and then you can unplug and put in the new ones. It took me awhile to change mine, I should of jacked the car up some so I had some room underneath but I didn't. Its nothing too hard, just not a lot of room to get at them. Hope that helps.
