1997 Dodge Neon - Crazy problems. One needs fixing. Please help.
Old Sep 3, 2006 | 04:52 PM
MAT420's Avatar
MAT420
Default 1997 Dodge Neon - Crazy problems. One needs fixing. Please help.
Hi, I'd appreciate any help at all. I have a 1997 Dodge Neon and first off my battery would
drain when I go to sleep overnight, but sometimes itd last for days. We fixed that by pulling the
fuse to my A/C that was under the hood (big square fuse that was accompanied by about 5-7
others probably) (it was keeping in the on position, you could actually hear it click on and off if
you wiggled the fuse). That was over with though after we pulled the A/C fuse. Then,
sometimes when you turned the key it would just click, banging on the starter working, or
bypassing the selenoid (by touchin them 2 nuts together on the starter/selenoid) but now, the
starter has been replaced and it does the same thing sometimes (it wasnt replaced long ago
but I think its the same case, I just dont get why the last one was dead complately and this one
is working one and off if its not completely the starter thats the problem, do i buy a brand new
starter? is something slowly breaking the starter?), and bypassing the selenoid doesnt even
work sometimes, you dont even see a spark when you touch them to nuts together which I was
told you should, no doubt about it. Since I've installed the new starter It only DIDNT start at all
ONCE, thats when nothing would work, from banging to bypassing the starter/selenoid, but a
few times, when I turned the key itd click, then I turn the key again and it would start. Is this a
power issue or what? I have a subwoofer and amp connected to my battery (one wire) that
both shut off when the car is off. The battery is brand new its definitely not the battery ive also
checked the volts and all of that. The starter, its my second one...I just dont think its the
starter again and neither does my friend who has been dealing with cars for a long time. I think
it may be another problem in that fuse box thats under my hood, but then, again, why was that
starter dead completely? Damn what I should have did was checked if that last one would
power up when connected to a power source. Anyway, Thank you so much for reading all of
that, I'd appreciate any help or suggestions at all.
Old Sep 5, 2006 | 10:18 PM
ewetho's Avatar
ewetho
Default RE: 1997 Dodge Neon - Crazy problems. One needs fixing. Please help.
Have your battery load tested if it is still good then probably just a bad replacement starter. Look for other drains though. Voltage should be above 12.45VDC (75%) to start (if you just turned off the car turn lights on for 30 sec. and then test voltage again.) If you have your multimeter you can test AMP draw should be about 30 mAmps or so. If much more you have something still draining the battery.
Old Sep 6, 2006 | 07:41 PM
Pharmboy's Avatar
Pharmboy
Have you tried simply cleaning the battery terminals and grounds, You should start there.
