engine swap
Possible? Yeah its possible alright. It might require a lot of work to do it, but possible definitely. Aren't mitsu's engines backwards? Which might make it a little more challenging to get it to work.
Its possible but for the money your going to spend swaping in that motor you could build the hell out of the motor you have and it would be a hell of a lot easier. You can even get a turbo kit with the same turbo the mitsu 2.0 uses.
