car wont start!!!
Old Nov 22, 2006 | 12:59 AM
geminisurfer13's Avatar
geminisurfer13
Default car wont start!!!
Please help, my car wont start. When I turn the key the lights, radio and stuff go on and it acts like it is going to start, then it doesn't. I don't know what it could be! Please help!!!! Thanks
Old Nov 22, 2006 | 01:08 AM
fullbuilt's Avatar
fullbuilt
Default RE: car wont start!!!
dose it crank. does it click. dose the power stay onwhen on start.
Old Nov 22, 2006 | 01:20 AM
geminisurfer13
The car turns over, but it doesn't start, gas is going to the carb, but no ignition.
Old Nov 22, 2006 | 10:21 AM
spudsterier's Avatar
spudsterier
gas would be goin to the injectors....there is no carb on neons
bad coilpack maybe????
did you check all your fuses???
Old Nov 22, 2006 | 10:56 AM
fullbuilt's Avatar
fullbuilt
lets start with spark. pull your plugs one at a time and set them against your spark plug cylinders. have someone crank the engine. if you dont have spark rplace spark plugs. if that dosent work, work your way back to the coil packs.
Old Nov 22, 2006 | 08:01 PM
geminisurfer13
Thank you I will try that!!!
