rear main seal
Old Dec 28, 2006 | 11:46 PM
houndog's Avatar
houndog
Default rear main seal
My rear main engine seal is leaking on my 1996 Neon. Do I have to pull the engine and transmission through the bottom of the engine compartment. The manual talks about a cradle that the engine sets on. Are they referring to something to sit the engine on?? Where do I obtain one of those??.....Jc
Old Dec 29, 2006 | 09:54 AM
spudsterier's Avatar
spudsterier
Default RE: rear main seal
it is easiest to remove the tranny through the bottom of the car.....just make sure its jacked up high enough
as for an engine cradle, you can just use a jack stand to hold it in place....
i use a ratchet strap.....strap one end to the exhaust manifold and the other across the engine to the radiator support......just to hold it still.....then use a piece of a 2x4 ontop of a jack stand and place it under the oil pan
Old Dec 29, 2006 | 01:38 PM
houndog's Avatar
houndog
Can I remove the rear main seal by removing the transmission and then removing the seal while the engine is still in the car??..........Jc
Old Dec 29, 2006 | 10:28 PM
JDC420's Avatar
JDC420
Yuppers Bob.
