Non Slip Differential.
Old Aug 27, 2004 | 01:34 AM
techmanbd's Avatar
techmanbd
Default Non Slip Differential.
Just wondering if anyone here put one in on there neon? was it hard to do? or fairly easy for someone who is mechanically inclined? And last, was it worth it?
Old Aug 27, 2004 | 09:00 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: Non Slip Differential.
VERY MUCH WORTH IT.
I've currently got a PG, they are a bit of a pain to get in but not too difficult with the right tools. And they are definitely worth the money. I know a few people with Quaiffes who swear by them and I know a lot of people with Phantom Grips.
Old Aug 27, 2004 | 11:43 PM
techmanbd's Avatar
techmanbd
how long do yo think it would take to put on, with the proper tools?
Old Aug 28, 2004 | 12:27 AM
Cr@zy Squ33
Well considering you have to remove the stock differential and put the LSD in it shouldn't take you any more than maybe 2 hours. However if you have no experience with working on tranny's add a few more hours.
Old Aug 28, 2004 | 12:52 AM
casper's Avatar
casper
Just to make sure we are talking about the same thing I have a Limited Slip Differental. I have never heard of a non slip??
Old Aug 28, 2004 | 05:14 AM
Cr@zy Squ33
Same thing just he called it something different.
Old Aug 28, 2004 | 01:20 PM
b_s_d's Avatar
b_s_d
ORIGINAL: Crazy Squee
Just curious: Was LSD ever a MOPAR option for the Neon or aftermarket only?
Old Aug 28, 2004 | 03:20 PM
Cr@zy Squ33
No. It was never an option from Mopar. The only car that I know of that now comes with a Quaiffe LSD is the SRT-4 from the factory.
Old Aug 28, 2004 | 04:27 PM
LowSlowNeon's Avatar
LowSlowNeon
You have a phantom grip squee? If so, just curious why that one is so much less than the quaife. Shed some light sir, you seem to know plenty.
Old Aug 28, 2004 | 04:56 PM
Cr@zy Squ33
That's the Phantom Grip. Basically, its two hunks of aluminum sandwitched together with springs in between it. there are a few different spring rates, Green, Yellow (also known as Gold) and Red. The Red springs are close to stock, Green is for track use and are only good for a few thousand miles, and the Gold is the street/strip rate. The Gold is what most people buy since the Green are damn near impossible to get and the Red is just a little better than stock. basically what it does is the diff pin goes through the middle of this and is pretty much locked which creates you limited slip.
And this one is the Quaiffe. As you can see the Quaiffe is an acutal differential not a block of aluminum. The reason why this is so much mroe expensive is because you are replacing the entire differential not just putting a piece of metal around your diff.
Both are good but apparent;y the Quaiffe is going to be better but there aren't many people who can fork out the $1200 for it so they opt for the less priced PG.
