Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
Need Wiring Info
Old Jul 17, 2007 | 12:36 AM
DaNicetro's Avatar
DaNicetro
Default Need Wiring Info
Hi, I am trying to install a Sony Bluetooth kit. Wondering if anyone can tell me the location of an easily accessible Accessory Wire? Power and Ground are no problem, but I am having trouble finding a good hookup for the accessory wire. Also if anyone knows if the stock radio has a mute wire that would be very helpful as well. Here is a link the the kit that I am installing. http://www.sonyericsson.com/spg.jsp?...&pid=10302
I had this installed in my last car and love it. If you have a Sony Ericsson phone I highly recommend it over the UConnect system since it has the caller id screen. I have even had friends hook their motorola phones up to it...although the phone book feature only seems to work with a Sony Ericsson phone.
Thanks
Old Oct 6, 2007 | 11:31 PM
rap_sucks_'s Avatar
rap_sucks_
Default RE: Need Wiring Info
You should be able to use an ignition wire, The accesory is a little harder to get at. Make sure to test first
Ignition 1PINK/WHITE 18 GAUGE(+)BEHIND DRIVER SIDE KICK PANEL OR IGNITION HARNESS
Accessory 1PINK/YELLOW(+)R.A.P. 14 GAUGE, BEHIND DRIVER SIDE KICK PANEL OR IN DRIVER DOO
Old Oct 14, 2007 | 06:33 PM
Jas_Oz's Avatar
Jas_Oz
just be carefull using the pink wire, I used that for a UHF CB and sometimes the car wouldnt turn off even with the key out, then id turn the CB off and the car would shut off!
Best to use the cig lighter acc wire
