Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
gas tank issues
Old May 1, 2011 | 10:47 AM
superdak05's Avatar
superdak05
Default gas tank issues
Sharon has a 2007 nitro, everytime she fills it up, the gas spews up the filler tube and onto the side of the truck, contacted dodge and brought the truck in, Dodge had to replace, tank, filler neck and check valve, apperantly, the ethanol the gas companies are using retains far more water then it should, everything was rotting out inside. If anyone has the same issues, contact dodge, these tanks and assemblies are on back order, because of the issues
Old Jul 26, 2011 | 09:28 AM
Hillfarmer's Avatar
Hillfarmer
Thanks for sharing this. My O8 Nitro has started doing the same thing. I did not even think of the possibility of it needing repaired. I will have to get this done before the warrantee expires.
Old Aug 22, 2011 | 10:47 AM
greenmachine's Avatar
greenmachine
When I first got the Nitro it did the same thing I just stopped sticking the filler nozzle into the neck as far.
