Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
Headlight problems
Old Jun 13, 2014 | 06:44 PM
Reider_35's Avatar
Reider_35
Default Headlight problems
hey I have a 2010 dodge nitro. Im having trouble figuring out this problem. My passenger side headlight isn't working. I swapped the bulb with the driver side headlight and same results. The high beam works but no low beam. I checked the voltage at the socket and im only getting 3.7 volts to the low beam socket. I also traced the wire back to the fuse box and everything seems to be alright with it. Any ideas on what could be wrong?
Thanks JR
Old Jun 13, 2014 | 08:23 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Check it at the socket terminals AND at the wire a couple inches away. Compare. The TIPM module is the output source for the headlamps. No fuses.
