Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
2011 dodge nitro battery slowly dying
Old May 26, 2018 | 11:19 PM
Ryan Walton's Avatar
Ryan Walton
Default 2011 dodge nitro battery slowly dying
The battery and alternator has been replaced I checked for corrosion on every sensor on the vehicle and it was all clear I checked for a blown fuse and everything was good when the vehicle starts to die all warning gauges come on and the battery light is the first to come on and then everything flashes before it dies what do you think is wrong please help thanks
Old May 26, 2018 | 11:34 PM
primem's Avatar
primem
Start the engine and measure the voltage at the battery. If its not at least 13.5 volts or higher you have a charging system problem. Normal open circuit battery voltage for a fully charged battery is 12.6volts. If the charging system isn't outputing higher that 12.6, the battery isn't being charged.
Report back with your results and i will walk you through diagnosis.
Puncutation and grammar would help; that run on sentence is hard to read.
