Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
Slightly weird oil leak
Old Dec 30, 2019 | 05:11 PM
Shlomo's Avatar
Shlomo
Default Slightly weird oil leak
Hello! So I’m helping my in-laws with their 2007 Nitro (4WD, 3.7L). They took it to a repair shop to have it looked at, and they said it has leaks at the front crankshaft seal and the oil pan. I went underneath it with a black light (they put UV dye in the oil), and confirmed that what’s leaking is oil, and I can see it coming from the front crankshaft and the oil pan just like they said. Here’s the slight catch: The oil dipstick shows the oil being completely full, however the vehicle *is* losing transmission fluid. I have no idea why this would be the case.
Their concern is that fixing the seals is going to cost about $1K, and that may not even be what’s really wrong. I was going to replace the seals myself, but that part of the transmission casing that would need to come off in order to get to it intimidates me. What am I getting into if I take that thing off? I’ve done quite a few repairs over the years, but I’ve avoided the inner workings of trannys and engines so far.
Old Jan 1, 2020 | 03:29 PM
rebeltaz83's Avatar
rebeltaz83
Pump seal is leaking, have to drop the trans. Or pull the engine. That cover in the first pic. Is just an inspection cover, no gaskets.
I put a clutch in my wife's 08, but it's a 2wd. Exhaust has to come out, front, rear driveshafts, would help to separate the transfer case from the trans, drop the cross member, any wiring, trans. Cooler lines. It's a good days job if everything comes apart ok.
