Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
No Heat Driverside: 2009 Dodge Nitro 3.4L
Old Nov 7, 2020 | 01:34 PM
Jacob Hiller's Avatar
Jacob Hiller
Cool No Heat Driverside: 2009 Dodge Nitro 3.4L
I have poured over the internet looking for solution. I am starting to think that a mouse house is blocking the a blend door.
Spoiler
I have been over everything as best that I can with out spending the 9+ shop hours to rip the dash out. I found.
2 actuators (both function).
1 fan speed resistor (all fan speeds function).
The heater **** when on defrost setting, and hi fan blows hot air out the passenger side and cold air on the driver side. When you turn the heat **** to cold the passenger side stops blowing and the driver side still only blows cold air.
I am not understanding the flow of the Plenum. How can it blow only cold air out the driver side and hot on the other side? Does anyone have a schematic or drawing? Where is the main intake? Where does the outside air come in? Is there another actuator? are all actuators electric? Is there vacuum lines?
I have pictures attached.
All shined up no place to gallop.
The upper driver side actuator (removed) dock.
Old Dec 5, 2020 | 11:46 AM
Jacob Hiller
EASY FIX! I just removed the heater core connections and back flushed the heater core with a garden hose. Problem fixed. I wish that I knew this was so easy!
Old May 3, 2021 | 11:57 AM
gmyhilo's Avatar
gmyhilo
Thanks for following up with the solution, it's the best way to help others.
