Dodge Pro Master The Dodge Pro master is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Pro Master in showrooms today!
2014 Pro Master 2500 A/C Issues
Old Feb 18, 2018 | 10:06 PM
Seeker469's Avatar
Seeker469
Default 2014 Pro Master 2500 A/C Issues
My A/C does not blow cold air. The blower motor is fine so I do at least get heat right now. When I press the A/C button which sits in the middle of the temp control ****, the green light comes on as does the Recirc light in the middle of the blower speed **** when pressed. The fan up behind the radiator does not come on and I hear no change in the engine or see a change in RPM when I try to engage the A/C. My big question is what fuses to check that would pertain to the AC? I want to check the obvious first before I start digging in under the hood. Also, I can see the coolant lines coming out of the passenger side firewall but I loose them once they turn towards the engine. Where you would add/check pressure for R134?.
Any direction or tips on what to check first would be highly appreciated.
Old Feb 19, 2018 | 07:47 AM
Need to put a set of AC gauges on it to properly diagnose. Take it to a shop.
