Dodge Pro Master The Dodge Pro master is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Pro Master in showrooms today!
Is the Ram Promaster capped at 5100lbs towing?
Old May 15, 2019 | 08:36 AM
Dodge_USA_Dude's Avatar
Dodge_USA_Dude
Default Is the Ram Promaster capped at 5100lbs towing?
Hi all, I hope this is the right section for this post. I was wondering if the Ram Promaster is capped at 5100 lbs. towing? All my research says it is, but I wanted to make sure there are no other engine options available. I'm looking for models between 2015 and 2017. Are those the same as the 2019s and 2020s or have they made significant changes to the engine since then?
Thanks.
