speedometer adjustment
Old May 4, 2007 | 09:01 PM
JimmyDiablo's Avatar
JimmyDiablo
Default speedometer adjustment
Wtih dodge, when we put bigger tires on the truck i.e. I have 315 70 17's as oppose to the 265 70 17's that are stock. Do I have too or is there a way to adjust the speedometer or does it remain accurate?
Old May 4, 2007 | 09:14 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: speedometer adjustment
th eold days, you re-geared the speedo cable.
now a days, the other guys were sayin the dealer has to reset the computer????
Old May 4, 2007 | 09:25 PM
timesublime's Avatar
timesublime
Some of the programmers let you set your tire diameter. All the computersees is the angular speed of the rear axle,one ofthe registersholds a value for the OD of the tire and the speedo reports based on those two values.
