tow haul/ overdrive
Ok correct me if you would. The way I understand this is if I choose
TOW/HAUL mode: I get all gears even overdrive at a little higher RPM. Is thiscorrect?
and if I select to cut out the
OVERDRIVE, No overdrive but do I get a little higher RPM as well? [&:]
Oh yeah this is on my 07...
that should be the way it works. the trans will shift a bit later/firmer to help in moving the load. locking OD out is good if you have an exhaust brake or if your pulling some hills and the tranny is constantly shifting in and out of OD.
ORIGINAL: Drew
ORIGINAL: Captain Squalus
TQ lockup is earlyer in tow/haul also
ORIGINAL: Drew
ORIGINAL: JotiGrains
My understanding of it, is that tow/haul is underdrive? My '05 has tow/haul, but it increases the RPM's, so that's a more simpler way of calling it underdrive?
In T/H, it modifies the shift points, pressure, TC lockup and the actual shift program. In the OD lockout, all it does is go up to 3rd gear and locks your TC.
Trending Topics
i run my truck in tow/haul most of the time....i live in very mountainous areas and it shifts up and down alot and in tow/haul it seems to do alot better..........is it bad to run in tow/haul alot?????????
