EGT Probe
Old May 25, 2007 | 03:00 PM
  #21
Drew's Avatar
Drew
Default RE: EGT Probe
I have a Jet Cal that I'll be working on next week. . .the probe clamps will push out 1000C thats just over 1800F
Old May 25, 2007 | 04:40 PM
  #22
jakebrake's Avatar
jakebrake
If your going to be bombing your truck you want the one in the manifold, or at least thats what the guy at the dyno told me (he was very specific to mention that I need to move mine to the manifold). I have mine after the turbo right now.
Old May 25, 2007 | 05:30 PM
  #23
Mayfair's Avatar
Mayfair
ORIGINAL: jakebrake
Have you gotta pic ??
Old May 25, 2007 | 06:00 PM
  #24
jakebrake's Avatar
jakebrake
Here ya go
[IMG]local://upfiles/30416/733EA58762EE4C5C88153D961CB9BB91.jpg[/IMG]
Old May 25, 2007 | 06:33 PM
  #25
Mayfair's Avatar
Mayfair
Thanks Jake !!
Did you have any problems drilling / tapping it out?
Old May 25, 2007 | 06:43 PM
  #26
jakebrake's Avatar
jakebrake
I actually welded a bung onto the down pipe. I have a really long thermocouple for some reason (maybe because it was originaly for a semi if I just tapped a hole, it would hit the other side of the pipe)
Old May 25, 2007 | 07:26 PM
  #27
Mayfair's Avatar
Mayfair
Where did you run all of the lines into the cab?
Old May 25, 2007 | 07:46 PM
  #28
jakebrake's Avatar
jakebrake
I cut a hole in the firewall and used a pass through connector. I'm slowly working all the gauges and the edge thru on of these connectors. Should make for a nice clean install.
Old May 25, 2007 | 08:00 PM
  #29
Mayfair's Avatar
Mayfair
What is a pass through connector?
How do you route fuel ( for the fuel pressure gauge ) and theEGT probethrough that thing??
Looks COOL !!!
Old May 25, 2007 | 08:19 PM
  #30
jakebrake's Avatar
jakebrake
If your using a mechanical fuel and boost gauge, you'll have to drill holes for the lines. With the egt, trans temp, ect you put the wires into the terminals on one of the connectors. On the other connector you match up your in cab wiring to the same pins on the other connector so that the trans temp wires match up with the trans temp gauge wires.
