Attitude turbo timer?
Old May 25, 2007 | 12:53 AM
Super Dave's Avatar
Super Dave
Default Attitude turbo timer?
I got my Juice/Attitude combo installed and boy does it wake the truck up I definately see myself getting a Southbend clutch before long[:@]
The main reason I went with the Attitude was that it's supposed to have a turbo timer. I installed the pyro probe after the turbo specifically because of that. But I can't figure out if mine has it, or how to get to the turbo timer screen.
Before I bought it, it read the manual on the Edge website for my year truck
http://www.edgeproducts.com/product....52&pvk=147
Its the EJD3000AWAM, and that is what the box mine came in says.
The online manual clearly shows the turbo timer functions, but it doesn't show how to get there from the menu. The booklet that came with mine doesn't say anything about a turbo timer.
Does mine have it, and I just can't figure it out???
Old May 25, 2007 | 01:48 AM
gresh1003's Avatar
gresh1003
Default RE: Attitude turbo timer?
I had the same problem. I bought my system from someone online and it was an older version. What you need to do is check the version # and find out what it is. I talked to edge and they said for $50 they would send me a totally new system with the newest version. I just got it today and the turbo timer is right there under the config. menu. You might have to get with edge and see if they sent you a old version.
Bobby
Old May 25, 2007 | 02:07 AM
Super Dave's Avatar
Super Dave
How do I check the version number? Does it display it when I first turn the truck on?
Old May 25, 2007 | 11:33 AM
cumminalong's Avatar
cumminalong
It should be right near the bottom of the "configuration" submenu.
If not, you have an older one without the timer.
Did it come with the key position sensor that you hook up under the steering column? This is what runs the turbo timer.
Old May 26, 2007 | 03:55 AM
Super Dave's Avatar
Super Dave
It says V 1.1 when it turns on for a second or two. There were no connections under the dash. I'll call Edge and see about getting an updated one.
