Hey drew
Old Jun 4, 2007 | 10:53 PM
jakebrake's Avatar
jakebrake
Default Hey drew
On a 2nd gen 24v is there enough room to sneak the pan out with out hoisting the engine off its mounts?
Old Jun 4, 2007 | 10:55 PM
Drew's Avatar
Drew
Default RE: Hey drew
I think you can sneak it out for a 2wd but not a 4wd . pumpkin being in the way and all
Old Jun 4, 2007 | 10:57 PM
jakebrake's Avatar
jakebrake
I noticed a little sound in the bottom end, wanted to see if it was a piston pin or something. While I had the pan off, was thinking about rolling in new bearings. Figured it couldn't hurt since the pan would already be off.
Old Jun 5, 2007 | 01:37 AM
Drew's Avatar
Drew
have fun. . .done it once. . .found a bearing sciezed to the rod. . .would rather not do that again.[:@]
yes, ended up having to pull the crank[:'(]
Old Jun 5, 2007 | 02:20 AM
SMOKINGREY's Avatar
SMOKINGREY
LOl thats no fun,well bearing are cheap insurance.
Old Jun 5, 2007 | 02:53 AM
Mayfair's Avatar
Mayfair
I had my oil pan replaced already and i don't remember them saying that they had to lift the engine, but i DO remember them saying that they had to remove the tranny.
Old Jun 5, 2007 | 02:58 AM
jakebrake's Avatar
jakebrake
Thats what I figure, bearings only cost around $50. Not much more than an oil change. Compare that to an engine if you loose a bearing.
