silencing ring
Old Jun 7, 2007 | 08:35 PM
amock's Avatar
amock
Default silencing ring
I have an 2003 cummins and am trying to get the silencing ring out and the baffling. Does anyone know which way the arrows should go on the tube with the baffling. Also am having trouble getting the ring out.
Old Jun 7, 2007 | 08:58 PM
nickcoletti's Avatar
nickcoletti
Default RE: silencing ring
the ring is pretty tightly packed in there, i just took mine out a few weeks ago and i had to play with a few diffrent flat heads for a little bit. keep tryin! now the baffles ive read about but not sure what they do. are they in the intake and what are the pro's of taking them out, just turbo noise?
Old Jun 8, 2007 | 01:25 AM
sallyman1's Avatar
sallyman1
anyone remove baffles?
Old Jun 8, 2007 | 01:57 AM
amock's Avatar
amock
The baffling is in the hard plastic tube on the intake tube itself. To get to it, just remove the softer tubes from that hard plastic. The baffling is inside there. Believe me, itsa pain to get out. Its just for more turbo noise. But there are arrows on the end of that hard tube.One end has one arrow and the other has two, im just trying to figure out which way those arrows are supposed to go.
Old Jun 8, 2007 | 02:45 AM
amock's Avatar
amock
I figured out how to put the tubing together. made me feel like a complete jackass. oh well, just sometimes how it goes. does anyone have some good tips on removing the baffling. your help would be much appreciated.
Old Jun 8, 2007 | 01:16 PM
donnie's Avatar
donnie
The easiest way is to take a hacksaw and carefully cut the baffles out.
There is a decsription on how to disassemble the tube on here in an earlier post but the easiest would be cutting the baffles.
There is no performance increase doing this other than hearing the turbo whine more.
Old Jun 8, 2007 | 01:58 PM
Drew's Avatar
Drew
take a dremel and cut off the outer rim on both sides. . .then take a hammer and tap the baffel out.
mine came out within a month of me owning the truck. it will make the turbo scream
Old Jun 8, 2007 | 05:24 PM
bert0168's Avatar
bert0168
What about the vanes in the lower rubber tube? Can they come out?
I just took out the baffles in the middle tube AND the ones in the lower tube but haven't driven it yet.
Their absence wont hurt the turbo, will it?
Old Jun 8, 2007 | 06:27 PM
moconst's Avatar
moconst
I took my vanes out of the bottom tube when I replaced my tube. Works fine for me.I think when you have a free flow intake you dont really need em.
Old Jun 8, 2007 | 06:44 PM
Drew's Avatar
Drew
all they do is help direct the air. . .but for the most part they are worthless. . .yank them
