Rough idle...blowing smoke
Old Jun 15, 2007 | 02:34 AM
sallyman1's Avatar
sallyman1
Default RE: Rough idle...blowing smoke
oh. what filter and how much? does it reduce your HP bigtime?
Old Jun 15, 2007 | 02:40 AM
jakebrake's Avatar
jakebrake
dpf cost about $1500 (in the otr world) these engines are built to have one. They won't run without them. Only need to worry about it if you buy the 6.7l
Old Jun 15, 2007 | 10:39 AM
Drew's Avatar
Drew
ORIGINAL: Ben D.
melt a piston? I dunno if a single injector dumping would be enough to raise egt's to melt that piston. but what do i know. I'm just thinking if a single injector failure can ruin a piston then these engines aint too tuff.
ask triton
Old Jun 15, 2007 | 02:15 PM
Mayfair's Avatar
Mayfair
ORIGINAL: ntc09
they say on of the rings came off and it was blocking the fuel inlet.
Didn't we have this happen to someone else a couple of months ago and I questioned him about the "rings"comming off? What was the final outcome of that discussion ... I can't remember.
Old Jun 15, 2007 | 04:40 PM
Ben D.'s Avatar
Ben D.
i'll take that as a yes it could melt the piston or "nuke a hole" right drew.
Old Jun 15, 2007 | 05:18 PM
Drew's Avatar
Drew
yup. . .if you had an injector to hang open you would be dumping raw fuel into the cylinder. when the heat builds up on the top of those pistons to a point the spray becomes a blow torch.
Old Jun 15, 2007 | 09:24 PM
jakebrake's Avatar
jakebrake
Piston then expands from heat faster than the cylinder walls the the piston starts to hang up causing major scoring or even worse, a thrown rod.
Old Jun 16, 2007 | 12:20 AM
Ben D.'s Avatar
Ben D.
I see now. I was just thinking that one leaky injector woudln't be that huge of an issue but nowthat you explain it I see. thanx for the knowledge guys.
