Diablo Power Puck
Old Jun 15, 2007 | 03:36 PM
Live44MX's Avatar
Live44MX
Default Diablo Power Puck
[align=left]I saw this item and it appears to be the perfect fit for my needs. I am looking for a little more power and MPG. I like the way it is inline. I am hoping it does not change the factory programing and that there won't be anything that they can detect if I had to repair it under waranty.[/align][align=left]http://diablosport.com/index.php?mod...lay&pid=78[/align][align=left]Has any one installed one of these by itself (no other programmer)?[/align][align=left]If so: any problems with it or install? Did you notice any power gains or MPG gains?[/align][align=left]Also does any one know how much it will advance the timing?[/align][align=left][/align]
The Power Puck remaps the fuel delivery of the diesel injection pump and advances the injection-timing curve.
The PowerPuck software works on changing the injection quantities an advancing the ignition curve, it will not alter the load pressure directly. The load pressure is increased due to the increase in fuel volume delivery. This in itself makes for an extremely reliable tuning device with one sole purpose, POWER!
PowerPuck equipped vehicles will notice significant improvements in drivability, whether it is in town, where speeds constantly change, or on the highway passing slower vehicles.
Power Puck increase’s power through the entire RPM range, at low RPM it will yield better throttle response; and help maintain speeds on inclines or when towing. The mid-to-upper power increase is extremely useful on the highway to maneuver through heavy traffic situations.
Stackable with Predator for a variety of performance levels[/align]
Old Jun 15, 2007 | 03:43 PM
Drew's Avatar
Drew
Default RE: Diablo Power Puck
this is a pressure timeing box. . .be carefull and dont crank it up all the way and leave it there or you may destroy your injectors.
a box like this is good for a little boost in power, and mileage since it increases the rail pressure, however I personaly dont like them just for that reason.
Old Jun 15, 2007 | 04:16 PM
Live44MX's Avatar
Live44MX
Thanks Drew, Do you know of a good one that inline and will have a small increase in power and MPG? I don't want much.. Not into the drag races even though I like them.... I found another that appears to be good... http://store.bankspower.com/Categori...c-934d558386bd
Thanks again and let me know what you think..
[/align][/align][/align][/align][/align]
Banks Bulletâ„¢[/align]
Boost Your Power and Read Your Boost!
Power
Three power levels: STOCK, TOW, SPORT. TOW adds about 30 hp; SPORT adds about 60 hp. Power adjustable on-the-fly.
[hr]
Boost
The Bullet is also a Digital Boost Gauge. A separate setting lets you select a boost level that will trigger the visual alarm (a red LED). Adjustable from 20-50 PSI in 1 PSI increments.
[hr]
Fueling
FUELING percentage displayed. Stock is always 100; higher numbers are stock + additional fueling from Banks Bullet. (140 indicates 40% more fuel delivery with Banks Bullet.)
[hr]
EGT
Requires thermocouple upgrade. The optional thermocouple equips the Bullet with adjustable temp limiting control. Set the temp limit and save your engine! Fueling limits are adjustable from 800-1500° in 50° increments. Exceeding the set EGT limit by more than 50° will trigger the visual alarm.
[hr]
Easy Mounting & Installation
The size of a standard 2†gauge, Banks Bullet can mount anywhere a gauge can go. Includes a single-gauge instrument mounting panel. An optional pillar-mount console is available (shown). [/align][/align]
Old Jun 15, 2007 | 05:02 PM
Drew's Avatar
Drew
banks is alright. . .however you can get more for less money.
check out TST's web site, they have some economy boxes.
Old Jun 15, 2007 | 07:01 PM
Live44MX's Avatar
Live44MX
Drew, I went to http://www.tstproducts.com/ I did not find any economy box's. The lowest price I found was $685. Is that the correct site? What product are you specificly speaking of?
Thanks for the info....
