Need more power!!!
Old Jun 15, 2007 | 06:11 PM
vinrum's Avatar
vinrum
Default Need more power!!!
Hey guys..I have a 1995 Dodge 3500 Dump. I haul alot of gravel and tow my bobcat ...I want to get some ideas for a little more power..Without killing my tranny!!!! Please give me some ideas for safe and reliable power up grades...
Thanks
Steve
Old Jun 15, 2007 | 09:22 PM
jakebrake's Avatar
jakebrake
Default RE: Need more power!!!
Start out with an intake and exhuast. Since it's a work truck, you'll probably want a muffler. Lot's of the guys on here like the aero 4040.
Old Jun 15, 2007 | 10:44 PM
finny's Avatar
finny
you might want to look at little bit more potent injectors? fuel plate? twin turbos?
Old Jun 15, 2007 | 11:07 PM
DieselDemon's Avatar
DieselDemon
How about a little more info.....milage, tranny, maintainence, etc.
I can get you there.
We have the technology.
You can be a force to reckon with.
What I do in 12, they can't do in 24. And it makes them sad sometimes.
Good luck with your ride.
Old Jun 16, 2007 | 10:07 AM
vinrum's Avatar
vinrum
Sorry about that...The truck has 130k on it, Automatic tranny, and 4 wd...What would I be looking at for a power increase with a muffler swap, or should I do the whole exhaust?? Thanks guys,
Old Jun 16, 2007 | 05:34 PM
DieselDemon
ORIGINAL: vinrum
If your tranny is original, I would not even think about serious power unless the tc is replaced with a multidisc version.
There's only one way to achieve more power. That's more air and fuel...lol.
Your factory turbo (Holset HX35) is limited in performance. You can get some HP gains by changing the fuel plate, kickin the AFC up a few notches, adding aperformance filter. (I actually have a brand new K&N filter that would fit your truck. PM if you're interested.)
Now when you add fuel, you inherit high heat with that as well. Large amounts of exhaust and that HX35 will keep your egt's right up there.
Our engines are 100 mechanical. You can change delivery valves in the P7100, add Bosch marine injectors, and advance the timing 1/2 -1 degree. Again, you will be adding heat. Knowing how to deal with that heat is what makes a good diesel runner.....lol. Gauges help monitor everything.
Like I said, start with an aftermarket air filter. You won't see staggering increases but you would notice a small difference in engine performance.
It all depends on how much scratch you wanna spend.
