HELP
Old Jun 20, 2007 | 01:50 AM
rausch42's Avatar
rausch42
Default HELP
I installed my edge with juice last friday and it kicked on a MAP sensor code but I figured it was because I started my truck up with it unhooked to clear out the manifold after I drilled it. But the damned light came back on tonight. Luckly I was by an Autozone and they let me clear it since I wasnt at work and didn't have the scanner handy
Old Jun 20, 2007 | 02:05 AM
firemansdodge's Avatar
firemansdodge
Default RE: HELP
If the truck doesn't sense the problem the light will not come back. You had the MAP sensor unplug and threw the light because it sense something wrong. As soon as you plugged it back ineverything is ok and you just needed to clear the check engine light.
Old Jun 20, 2007 | 02:38 AM
moconst's Avatar
moconst
Default RE: HELP
So what do you need help with?
Old Jun 20, 2007 | 11:44 AM
rausch42's Avatar
rausch42
Default RE: HELP
it keeps coming back on though is my problem and was wondering if anyone has ran into this before
Old Jun 20, 2007 | 01:35 PM
Drew's Avatar
Drew
Default RE: HELP
after 5 full starts if the light doesnt go away then you may have an issue.
is your truck running like it should or does it feel like it is defueling???
Old Jun 20, 2007 | 04:50 PM
rausch42's Avatar
rausch42
Default RE: HELP
it runs good when the light came on it kind of stumbled but then it has been working fine ever since then. It just bothers me that it is the second time in less thena week that it came on.
Old Jun 20, 2007 | 04:59 PM
Drew's Avatar
Drew
Default RE: HELP
if it is running fine right now you may not have an issue. give it some time to clear out on its own.
Old Jun 25, 2007 | 01:47 AM
rausch42's Avatar
rausch42
Default RE: HELP
i went on a road trip this weekend and soon as i hit the highway i kicked on a p2146 & p2149 then it gets worse my truck just died.the truck would not restart so i disconnected the edge and started right up should i sendit back to edge?
Old Jun 25, 2007 | 03:48 AM
speakle's Avatar
speakle
Default RE: HELP
I would certainly at least call them.
