Warning lights
Old Jun 24, 2007 | 11:45 PM
Budlite's Avatar
Budlite
Default Warning lights
ABS and Brake lights stay on. Have plenty of brake fluid. Brakes work fine. 2002, 2WD 3500 dually, 49000 miles.
Old Jun 24, 2007 | 11:52 PM
SpLaT's Avatar
SpLaT
Default RE: Warning lights
Check the wiring at theback end .. theres aconnection atop of the rear pumpkin, you may have some dirt or water in the connection or like mine.. a rock took it out.. got it tapped together been good last 3 months now.
Old Jun 24, 2007 | 11:58 PM
mako53's Avatar
mako53
try changing your vehicle speed sensor its towards the back of the transmission mine had that and no bus in the odometer i changed it and it runs fine the part is less than $20 autozone but beware of the transmission fluid hitting you in the face
Old Jun 25, 2007 | 12:11 AM
cmnspwr's Avatar
cmnspwr
Do you have some sort of a box on there? When I first put on my Smarty, the ABS and Parking Brake lights stayed on. After a few times of starting up the truck, it went away.
Old Jun 25, 2007 | 12:26 AM
Budlite's Avatar
Budlite
It's bone stock. also has 6spd manuel trans.
