ALTERNATOR PROBLEMS
Old Jun 25, 2007 | 01:09 AM
Chuto's Avatar
Chuto
Default ALTERNATOR PROBLEMS
Hope someone can help me. I have a 05 3500 diesel that I converted into a Repo vehicle. I have an electric lift with 2 motors on it pulling 50 amps each, plus my inverter for my laptop, gps, flashlight charger etc. The stock alternator is not cutting the ice. I have the proper thickness cable running from the batt to the motors. Aprox 6 ft. everything I pick up is at idle. Does Dodge make a duel alternator setup or do I just need to get a high output one? If so can you recommend one? Mike
Old Jun 25, 2007 | 01:16 AM
Captain Squalus's Avatar
Captain Squalus
Default RE: ALTERNATOR PROBLEMS
Repo man asking for help is like a tax colector asking for help. hehehe
Old Jun 25, 2007 | 01:26 AM
FroneDaddy's Avatar
FroneDaddy
ORIGINAL: Captain Squalus
Lol
Old Jun 25, 2007 | 01:27 AM
Little Foot's Avatar
Little Foot
Have your high idle turned on at the dealership. It allowed my winch to function way better after having the engine set at higher rpm's. This should help you out with your lifts and such. With your truck running in park turn on your cruise control and then hit the set button. If it is already enabled you will hear the engine increase the rpm's
Old Jun 25, 2007 | 01:43 AM
Chuto's Avatar
Chuto
The REPO is the easy part, its the alternator thats the problem
