lots of questions
Old Jun 27, 2007 | 05:24 PM
pngmotoman's Avatar
pngmotoman
Default lots of questions
Well i'm new to the CTD and i want to put more power into it (of course). What i was wondering what is better to get a torque convertor or a valve body to handle the little extra i want to get (exhaust, intake and edge). If either which type do you guys like?? then also wanted to know where to get a good price on the Edge w/attitude??
Also looking at getting a leveling kit and i'm really impressed with the Kore products. I have been looking for a price on the kit and cant find anything all i have seen is people sasying how expencive they are but not what they payed. Hope this is not to much just lots of questions i dont want to throw down all this money and then start breaking stuff i'm just a low ranking airman.
Old Jun 27, 2007 | 05:49 PM
SpLaT's Avatar
SpLaT
Default RE: lots of questions
Welcome to the "Dark Side".....
First off, what kind of driving conditions do you expect?... normal driving pavement/gravel roads, some off roading or lots of off roading? Guages should be your first upgrade... boost, pryo, fuel pressure and tranny temp( I perfer the analog gauges over the digital). Then if you just want to run larger tires a cheap +/- $200.00 leveling kit allow you to run 33"-35" tires. For some more agressive offroading or washboard roads a Kore Chase system (gives you about 50% more travel over stock)will run ya about $2500 to $2900.00. Next would be intake and exhaust as for the exhaust I dumped the cat and stock muffler to open it up, with factory 4" pipe.. its pretty much all I need. A cheap and good addition of 70hp is the Predator chip around $400.00 this chip won't require you to upgrade the tranny which with a torque convertor and VB could easily run $2000 to $3500.00 or better yet get a "race or built" tranny for around $5000.00. The predator chip will give you better fuel economy and the extra HP/torque for a basic set up.
Good luck with your CTD!
Old Jun 27, 2007 | 05:59 PM
pngmotoman's Avatar
pngmotoman
i live in alaska so i go down lots on dirt roads. that is why i was looking into the kore because it changes the springs up front instead of putting the spacer in. thanks for the info.
Old Jun 27, 2007 | 06:15 PM
R0oster31's Avatar
R0oster31
I picked up my edge w/attitude for 650 from autoanything. I've got the 6 speed though as do my buddies, so I don't know much about the autos.
Elmendorf? I wouldn't mind getting stationed there in a couple years.
Old Jun 27, 2007 | 06:26 PM
pngmotoman's Avatar
pngmotoman
Eielson but elmo would be better. on auto anything the cheapest i can find for the juice w/ attitude is 899.10. did you have to call direct??
Never mind just saw you have a 02 and looks like they are cheaper than the 06
