Diesel Grades?
Old Jun 28, 2007 | 01:31 AM
Tommygunz's Avatar
Tommygunz
Default Diesel Grades?
This may sound utterly retarded, but the question is nagging me. At almost every fuel outlet there is but one choice for diesel. Yet at a rare few there are two. What is the differance between #1 and #2? Can I run either? Are there gains to be had by running one versus another. I know at the stations that sell both, one is generally much more expensive than the other.... Can someone please enlighten my retardation?
Old Jun 28, 2007 | 01:35 AM
jakebrake's Avatar
jakebrake
Default RE: Diesel Grades?
#1 is basically kerosene. Usually it is only in the colder areas in the winter as the gel point is lower. It's harder on your fuel system as there is less lubrication than #2.
Old Jun 28, 2007 | 01:43 AM
Tommygunz's Avatar
Tommygunz
So would you recommend running it in the winter or using an additive to defeat the gelling?
Old Jun 28, 2007 | 01:51 AM
jakebrake's Avatar
jakebrake
I would run additives. If you were going to run #1 I would put a lil2 stroke oilin it.
Old Jun 28, 2007 | 01:57 AM
Tommygunz's Avatar
Tommygunz
Thanks Jake... Why do your suppose the kerosene is so much more expensive?
Old Jun 28, 2007 | 02:09 AM
jakebrake's Avatar
jakebrake
Not sure, could be more taxes on it.
