Attitude only
Old Jul 2, 2007 | 02:12 PM
savage.basher's Avatar
savage.basher
Default Attitude only
I would like to monitor some things, mostly onlyboost and egt's (since the truck is basically stock). Would it be a good idea to get just the Edge Attitude monitor and then when I get enough money proceed with the Juice box to go with it? I assume the Attitude will work by itself, am I wrong? Does anyone know exactly what item I can monitor with just tthe Attitude monitor? I thought about just getting boost and EGT guagesand putting them on an A pillar mount but by the time I do that I will have $200 in guages that I will likely not use once I can afford both the Attitude and Juice. The attitude is $300 by itself (I think) and I wouldimagine this would be the better route since I would be able to continue to use it with my juice box. Any advice would be greatly appreciated.
almost forgot - Does anyone know if the Attitude can store max values (for example the highest EGT reading that is monitored??), that way I could reset it before I loan my truck to someone, and then check it when I get my truck back to make sure they didn't abuse my baby.
Old Jul 2, 2007 | 02:24 PM
aka_chewy's Avatar
aka_chewy
Default RE: Attitude only
I don't know for sure, but I think that you need the juice box in order for the attitude to get all the readings from the computer. I think even the pyro probe is connected to the juice.
Not sure if that helped or not, but it would be sweet if you could run it with out the juice
Old Jul 2, 2007 | 02:35 PM
savage.basher
CRAP!!!You're probably right. I guess I shouldn't get my hopes up untill some one posts who actually has one though. Thanks man.
Old Jul 2, 2007 | 04:44 PM
firemansdodge's Avatar
firemansdodge
Can't use the Attitude w/o the Juice. I great digital monitor that attaches to your A pillar just like the Attitude is the Quadzilla Commander. Has every possible guage display that you will need (egt, boost, tranny, fuel pressure + many more). You can also hook up other programmer/tuners to the monitor for tuners/programmers that have shift on the fly capability.
Old Jul 3, 2007 | 10:28 AM
savage.basher
Damn, oh well. I guess I can look into one of these other ones, thanks Fireman.
