help me please!!
Old Jul 15, 2007 | 11:34 PM
jjd0318_1's Avatar
jjd0318_1
Default help me please!!
hey whats up everyone...i was told this forum could help meso i signed up, so here goes.ive got a 2004 cummins dually 4x4 6 spd and the fuel delivery keeps cutting out.lift pump and injection pump test fine. when i do the on acc on etc thing it gives me codes p2122 p2121 p 2146 and p2149,i got about 130.000 any help and suggestions is greatly appreciated, thanks in advance
-Jose-
[IMG]local://upfiles/67889/67B48604A4D843369A1AED2851037037.jpg[/IMG]
[IMG]local://upfiles/67889/454C51EA83E24327B4496DDE5015EF74.jpg[/IMG]
[IMG]local://upfiles/67889/9595CD85DD1B42C1950BE0BD6B8439AF.jpg[/IMG]
Old Jul 15, 2007 | 11:50 PM
jakebrake's Avatar
jakebrake
Default RE: help me please!!
How much fuel pressure you getting up to the injection pump? The lift pumps on these things are known to go bad. Since you got such a big list of codes, I would clear them and see which ones come back as you drive it around.
Old Jul 15, 2007 | 11:58 PM
bksram3500's Avatar
bksram3500
I can't help you with your problem but I would like to say nice truck and welcome to DF.
Old Jul 16, 2007 | 12:05 AM
firemansdodge's Avatar
firemansdodge
What is the fuel pressure when you tested? Any kind of smoke when start up or rough idle?
Old Jul 16, 2007 | 12:24 AM
jjd0318_1's Avatar
jjd0318_1
this might be kinda dumb but how do i chek the pressure and how do i clear the codes to see which come back, i took it to a local shop and they are the ones that said both my pumps are good.
Old Jul 16, 2007 | 01:01 AM
firemansdodge
From your post sounded like you had a fuel pressure guage.You can clear the codes if you have a code scanner or a programmer that clears codes. Since your losing power there is something wrong. If you have a tuner installed. Check the harness for the connections.
Heres what the codes mean.
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2146 Fuel Injector Group 1 Supply Voltage Circuit
Old Jul 16, 2007 | 01:20 AM
JimmyDiablo's Avatar
JimmyDiablo
Welcome to the forum. I don;t know a lot myself but you will find great help here.
Old Jul 16, 2007 | 04:24 AM
jjd0318_1's Avatar
jjd0318_1
i do have the edge programmer with monitor
Old Jul 16, 2007 | 12:28 PM
firemansdodge
Codes 2121, 2122 can be traced back to the fue l(gas) pedal. There is a cable that runs from the pedal into the engine compartment. Check the cable.
The other two codes might be a bad ECM or check the injector harness and wiring. This may be required to take to the dealer or a good diesel mechanic to verify.
Old Jul 16, 2007 | 07:54 PM
jjd0318_1's Avatar
jjd0318_1
so i went to the dealer and the injector codes were cleared and never returned,codes 2121 and 2122 returned and was told i need a new bell crank (throttle postion sensor)so i purchased it but they wouldnt tell methe exact location,prolly a scam just to get me to spend more.called three dodge dealerships and got 3 responses,1 under the hood 2 in the compartment,3 near the tank.i tried to look myself but just started gettin frustrated. lil more help por favor
