Hmmm... Interesting
Old Jul 20, 2007 | 04:29 AM
kg1687's Avatar
kg1687
Default Hmmm... Interesting
Recently put new gear oil in my rear diff and front diff since the old oil got saturated with water and such. I put Lucus synthetic 80-90W ran my truck a bit and keeping an eye on it. No water in the oil. but noticed that theres a few tiny metallic shavings on my magnetic fill plug. could this be cause from A - the short pull with water in gear oil from stuck place to my home. B - Rear wheel bearings being over tightend? C- Bad mix of oil for rear gears. I can't imagine me running it enough to really wear the rear end so I'd imagine that it's stuff that has been in there but I could always be wrong. Just trying to find out if I should go along the lines of removing lucas gear oil. switch to something else. Just let it run a bit because it's previous wear. Or change tightness of rear bearings. The rear bearings we tightened up just to where the wheel wouldn't shake. perhaps they might be too loose? So many possiblities. Also on all the parts on the truck that i imagined having problems. the bearings stay the coolest after I ran it and I greased em. So.... Just looking for pointers. just came to mind right now.
Old Jul 20, 2007 | 11:49 AM
Drew's Avatar
Drew
Default RE: Hmmm... Interesting
unless there are HUGE chunks it would just be something to keep an eye on.
Old Jul 20, 2007 | 04:01 PM
kg1687's Avatar
kg1687
no huge chunks, just lil tiny shiny pieces on the magnet like i said. Thanks for the help drew.
Old Jul 20, 2007 | 04:28 PM
NickBeek's Avatar
NickBeek
Wasn't there a problem with the AAM axles where the "C" clips came off and rubbed something in the diff?
Old Jul 20, 2007 | 04:43 PM
finny's Avatar
finny
if your truck is farely new it could just be from being broken in.
Old Jul 20, 2007 | 04:51 PM
CowboyBob's Avatar
CowboyBob
It sounds more like normal wear and tear. Mine was similar the first time I changed it.
Old Jul 20, 2007 | 07:38 PM
jakebrake's Avatar
jakebrake
Normal wear. As for bearings, tighten the crap outa them then back them off. Then tighten them to 50 ftlbs then back off a 1/4 turn.
