squeeking noise only in reverse
Old Jul 21, 2007 | 03:12 PM
amock's Avatar
amock
Default squeeking noise only in reverse
I have a 03 2500 cummins, when backing up in slow speeds got a squeek that will speed up as the truck speeds up, i think its a u joint, if so, how hard are these to replace and any advice would help. thanks
Old Jul 21, 2007 | 05:20 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: squeeking noise only in reverse
I remember having that same problem on a Dakota i used to own... Check your drive shafts and see if there are any rubber boots/grommets or what ever you'd like to call them.... If there is... get a good lube... preferably in an aerosol can with that little red straw .... .and shoot some into the rubber parts... try that and see what happens....
Old Jul 21, 2007 | 07:28 PM
Drew's Avatar
Drew
yup. . .u-joint going out. . .they arent that hard to replace, just a snap ring, use a brass drift pin and a hammer and your good.
Old Jul 21, 2007 | 09:12 PM
somebodyinok's Avatar
somebodyinok
Table vice works wonders too.
Old Jul 22, 2007 | 12:33 AM
speakle's Avatar
speakle
I had a 1994 s10 blazer that did that same thing but in drive. Squeek squeek squeek. That was a long time ago but I remember having to use a vise with a socket and something else to push it apart. My vise wasnt strong enough so it went with my dad to work where they had a 50 ton press...that did the trick.
Old Jul 22, 2007 | 04:12 PM
brutusjr357's Avatar
brutusjr357
Member
I had the same thing happen on my 2005 and it was the rear u-joint they dont have a grease zert so mine ran dry and made noise only in reverse...
