Boost and pyro questions
Old Aug 4, 2007 | 12:41 AM
gtxpooch's Avatar
gtxpooch
Default Boost and pyro questions
When I was driving on the freeway today 65/75 the boost was only showing 1 to 7 or 8 and the egt's were all over the place. Aren't they supposed to stay fairly steady unless accelerating?
Old Aug 4, 2007 | 12:43 AM
jakebrake's Avatar
jakebrake
Default RE: Boost and pyro questions
If your cruiseing on level road at a constant speed, the guages shouldn't fluctuate.
Old Aug 4, 2007 | 08:13 AM
speakle's Avatar
speakle
What do you mean when you say all over the place?
Old Aug 4, 2007 | 03:57 PM
Cumminnotstrokin's Avatar
Cumminnotstrokin
Check your hose from the turbo to the inter cooler and from the inter cooler to the intake. I had a similar problem on my 98 TCD ended up being a bad hose clamp off of the turbo
Old Aug 4, 2007 | 05:38 PM
gtxpooch's Avatar
gtxpooch
Egt's were from 580 to 940-50 wouldn't stay the same for very long even with cruise on, level road. I wouldn't think any hoses would be loose in 16K miles.
Old Aug 4, 2007 | 05:42 PM
FroneDaddy's Avatar
FroneDaddy
Gauge connections coming loose.............maybe
Old Aug 4, 2007 | 05:43 PM
Cumminnotstrokin
I had 2 loosehoses on my new 2006 one was a little hose behind the turbo I think it went to the heater core. The other was on the reservoir for the radiator. It wouldn't hurt to check the turbo boots
