Leaking Fuel rfon top of water seperator cansister.
Old Aug 12, 2007 | 11:19 AM
cstric1's Avatar
cstric1
Default Leaking Fuel rfon top of water seperator cansister.
My deseil truck is leaking feul from the top of the fuel/water seperator canister. We changes the filter and replaced the o-rings and seals. It is still leaking. Any suggestions?
Old Aug 12, 2007 | 12:01 PM
finny's Avatar
finny
Default RE: Leaking Fuel rfon top of water seperator cansister.
welcome to the forum.
what year of truck do you have?
Old Aug 12, 2007 | 12:08 PM
htgriffith's Avatar
htgriffith
Only thing I could think of would be that the "O" ring must be cut or not seated good. It does not take but a small cut on a "O" ring to make it leak. Ifit was not flush with the top when you screwed it on you could have cut it a little bit................
Old Aug 12, 2007 | 12:17 PM
NickBeek's Avatar
NickBeek
What's been said above plus..... That cap is made of plastic, I would think if it was overtightened it could crack pretty easy. It also would be pretty easy to cross thread which would not let it seat the o-ring properly.
