Turning Key Beep Off ?lse with an 07 has had a problem turning the "Key Beep" off when locking the d
Old Aug 21, 2007 | 05:25 PM
roadrnnr's Avatar
roadrnnr
Default Turning Key Beep Off ?lse with an 07 has had a problem turning the "Key Beep" off when locking the d
Was wondering if anybody e
Old Aug 21, 2007 | 10:35 PM
Parts/Service's Avatar
Parts/Service
Default RE: Turning Key Beep Off ?lse with an 07 has had a problem turning the "Key Beep" off when locking the d
try this
HORN CHIRP DISABLING / ENABLING
The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To DISABLE (cancel) the horn chirp feature:
1.
Enter the vehicle and close all doors.
2.
Fasten the seat belt (this will cancel the seat belt chime).
3.
Turn the ignition to the ON position.
4.
Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons.
5.
Turn the ignition OFF.
6.
Turn the ignition ON or wait 60 seconds.
7.
Test the horn chirp feature by pressing the LOCK button.
If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure.
To ENABLE the horn chirp feature, repeat the above procedure.
