Tranny doin some weird stuff!!!
Old Sep 1, 2007 | 04:07 PM
  #21
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Tranny doin some weird stuff!!!
Whoa. Hold on. My father had the same problem in his 98 and he talked to a transmission guy and he said there was a solenoid, I forget what it is called, that has a little spring in it that goes bad. He gave my father a rebuild kit for the solenoid and it fixed the problem.
Old Sep 1, 2007 | 07:06 PM
  #22
Drew's Avatar
Drew
ORIGINAL: Jr. Mechanic
and it could be that may be the problem. . .but this will tell you one way or another. . .and it's a free fix
Old Sep 1, 2007 | 11:53 PM
  #23
miknwv's Avatar
miknwv
a pressure solenoid?
i got under the truck, wiggled every wiring harness i could find, freed 'em up a bit and it hasn't done it even once since. =)
Old Sep 6, 2007 | 02:14 AM
  #24
Flent's Avatar
Flent
I understand that having them adjusted under normal conditions needs to be paid for but when the truck is brand new and has like 10,000 miles on it and you tell the dealer you have noticed it for a while.. shouldn't it be coverd?
Old Sep 12, 2007 | 01:00 AM
  #25
canmaninusa's Avatar
canmaninusa
New Member
How much can one expect to pay to get the bands adjusted on the tranny for a 2005 CTD? And also does anyone know what the outcome/difference is if the bands are too tight or too loose, what would one expect too see from both scenarios.
Thanks
Old Sep 12, 2007 | 02:11 AM
  #26
Mayfair's Avatar
Mayfair
Cleaning both ground wires on my batteries and the ground to the engine fixed my tranny good as new. It's a VERY common problem, but not a well known solution. I took my Ram to a tranny shop and just by luck the problem was just discussed in some sort of tranny magazine that gets sent to tranny shops. The guy had just read it and it was fresh on his mind. he told me to take it home and clean up the grounds. if I still have probelms, bring it back.
That was last year and Thank God I'm still shifting fine ( knock on wood ... )
Old Nov 27, 2007 | 07:20 PM
  #27
miknwv's Avatar
miknwv
found hte problem....like you all said, was a loose main ground, found it loose on the battery terminal. tightened it up and its like a brand new tranny
Old Nov 27, 2007 | 08:05 PM
  #28
Drew's Avatar
Drew
good to hear
