Need some tech help on 01
I have not been able to find a gasket for the timing cover. I have to replace the harmonic balancer seal on the timing cover andI am a little unsure what product I have to use to seal the timing cover after replacing the seal.
I have resealed the vacuum pump, fixed that leak, I believe there is oil coming from the seal on the harmonic balancer, are there any other possibilities here?
well, that link didn't work. Ok, go to that link, put in the year. make and model of your truck. Then on the left, choose " engine " then under engine choose " cam shaft timing " then double click "front over gasket " you shold then see a diagram of the engine to pick and choose parts you need
The gasket you need is $45
If you look at the diagram, there are 2 covers there. I am only taking off the front cover, it does not show a gasket. Should I use silicone form a gasket to replace the cover?
BTW, thanks for the link, i saved it to my favorites!!!!
