dana 60 / 70 question
Old Sep 20, 2007 | 08:31 AM
hohner's Avatar
hohner
Default dana 60 / 70 question
My '99 CTD 2500 has 3:54 gears and I'm picking up a set of 4:11 gears for it...will my present d60 & d70 carriers accept the lower (4:11) gears or will I need to get new carriers? Thanks!
Old Sep 20, 2007 | 05:28 PM
Drew's Avatar
Drew
Default RE: dana 60 / 70 question
you should be fine
Old Sep 20, 2007 | 10:44 PM
jakebrake's Avatar
jakebrake
You need to get the thick ring gear and pinion set for the rear axle. The carrier swap is at 3.73 for the rear but you can get a "thick" ring gear set and get by without a carrier swap. The front carrier swap is at 4.10s so your goo there.
Old Sep 20, 2007 | 10:50 PM
hohner's Avatar
hohner
OK, thanks guys!!
