exhaust
Old Sep 23, 2007 | 01:29 AM
bigp38's Avatar
bigp38
Default exhaust
Iam trying to make my truck loud as possible i cant straight pipe it because it is an o7 . I have no cat,no silencer ring,gutted the intake with an k&n filterand a 12 inch dynomax muffler that stops right behind the cab but it still dont sound right. Just wondering if anyone has tried a chambered muffler and is it louder or quieter than a straight through. Anything else i can do to make my truck louder
Old Sep 23, 2007 | 01:31 AM
jakebrake's Avatar
jakebrake
Default RE: exhaust
Is it the 6.7?
Old Sep 23, 2007 | 01:37 AM
bigp38's Avatar
bigp38
Default RE: exhaust
no its a 5.9
Old Sep 23, 2007 | 01:40 AM
jakebrake's Avatar
jakebrake
Default RE: exhaust
Then you can straight pipe it no problem. The emissions junk that you can't remove is on the 6.7.
Old Sep 23, 2007 | 01:43 AM
bigp38's Avatar
bigp38
Default RE: exhaust
i tried that it sounds like a gas motor that is misfiring it has to have some back pressure lilfroger did it but mine sounded like it was sick
Old Sep 23, 2007 | 07:46 AM
FroneDaddy's Avatar
FroneDaddy
Default RE: exhaust
Mine is straigh piped and sounds great, you don't need back pressure. You're truck isn't going to sound any differentfrom mine.
Old Sep 23, 2007 | 10:45 AM
steve05ram360's Avatar
steve05ram360
Default RE: exhaust
you could straight pipe it and dump it right behind the cab...
Old Sep 23, 2007 | 12:11 PM
bigp38's Avatar
bigp38
Default RE: exhaust
yes it does i have a friend with an 04 his sounds good mine sounds sick if i leave the cat on its ok i dont understand it
Old Sep 23, 2007 | 12:16 PM
bigp38's Avatar
bigp38
Default RE: exhaust
its dumped right behind the cab but when you hit the throttle it sounds a little rough i dont know what to do i might just go back stock this is a lot of trouble thanks for your help[/align]
Old Sep 23, 2007 | 12:25 PM
handymanherb's Avatar
handymanherb
Default RE: exhaust
Engines, even the same type are different, I had an old 66 Chevy straight 6 that you could not keep a muffler on and it was just as quite without the muffler as it was with it on, I put it on for inspectiononce a year and withing 2 days it would drop it, I 'll stop and put it up till next year.
Now I had a Chevy Nova wagon with the sameengine and you couldn't stand it without a muffler and it wouldn't run as good either
