Quick oil change plug.
Old Sep 27, 2007 | 12:00 AM
XTRIK8's Avatar
XTRIK8
Default Quick oil change plug.
I just saw the post that had a pic of a quick oil change plug from Geno's Garage and now I can not find it. I went to Geno's and he had two models, the EZ Change Plug and the Finger Touch Oil Drain Valve. Any input pro or con on either? Thanks!
Old Sep 27, 2007 | 12:05 AM
steve05ram360's Avatar
steve05ram360
Default RE: Quick oil change plug.
finger touch... with the lever. look in the DIY thread at the top... I think I posted a link up there...
Old Sep 27, 2007 | 12:09 AM
steve05ram360
here it is...
https://dodgeforum.com/m_962817/tm.htm
Old Sep 27, 2007 | 01:03 AM
handymanherb's Avatar
handymanherb
Go with the finger touch, the last oil change I did bare handed no tools, place drain pan and lift and turn the quick drain, then reach up and loosen the filter, then get a baggie big enough to hold the filter, slide it over the filter and remove it,the bagwill catch that little oilyou lose when you have to tilt the filter to get it out, empty the filter into the pan, close the bag and throw the filter away, close the drain valve,dump in three gallons of oil and your done, all nice and clean.
Don't forget to recycle the oil
Old Sep 27, 2007 | 09:11 AM
XTRIK8's Avatar
XTRIK8
Thanks for the replys!
Old Sep 27, 2007 | 10:03 AM
GlenninTexas's Avatar
GlenninTexas
I just purchased aFram Sure Drain SD-5 for my truck from ebay. Got the item on auction fo r 99 cents and paid $5 for shipping. You can pay $21.99 from Jegs for the same thing. Haven't installed it yet though.
Regards, Glenn
