Hey Sharx
Old Oct 9, 2007 | 06:51 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: Hey Sharx
ORIGINAL: jakebrake
Did your what?!!![:-]
Jake, I thouhgt you were recording it all?
Old Oct 9, 2007 | 06:54 PM
sharx ram's Avatar
sharx ram
ORIGINAL: KillerCummins
Wow, thanks for the offer Sharx!Can I take a raincheck until Iget my rig to power brake? I'm sorta at a stand still. I've seen that vid of yours smokin' it up. Very cool. I think I'm just making my way to a new turbo, but if you have any advice, I will take it. [sm=hail.gif]Thanks again!
Power braking with 4 wheel disk is a pain to get used to, you have to apply just enough to hold the truck in place and crank up the boost, put some water under your tires will help also plus it will save some of your tread.
jakebrake's Avatar
jakebrake
I was but the dvd has a scratch in it, so it skips a lot[:@]
Old Oct 9, 2007 | 07:01 PM
JimmyDiablo
ORIGINAL: jakebrake
I guess it is not like we wont have a opportunity to record Sharx gettting violated ever again. [8D]
Old Oct 9, 2007 | 07:06 PM
jakebrake's Avatar
jakebrake
Expeciallywith all these weirdos that get togther in AZ
Old Oct 9, 2007 | 07:09 PM
KillerCummins's Avatar
KillerCummins
ORIGINAL: sharx ram
Thanks.I can spin the (you know what) out of them when theres water on the ground, but I want to be able to do it on dry asphalt... So my quest continues.Can you PB on dry asphalt? (If you don't mind me asking) What mods & tires size are you running? Thanks again
Old Oct 9, 2007 | 07:26 PM
sharx ram's Avatar
sharx ram
Yes you can, but like I say it takes just the right amount of pressure on the brakes, Im running the Edge "Hot" Juice with Attitude, cold air intake and 35"x13.50" ProComp A/T's. With just the right amount of brake pressure you should be able to do it once youve got enough boost. But with 37" tires I recommend putting water down to protect them the best you can and to put less wear and tear on the rear end. You wont need alot of water, just enough to get them spinning.
Old Oct 9, 2007 | 08:03 PM
JimmyDiablo
ORIGINAL: sharx ram
Sharx, you have never been worried about wear and tear on your rear end before. Did Jake abuse you?
Old Oct 9, 2007 | 09:45 PM
jakebrake's Avatar
jakebrake
No wear and tear in his rear, sharky uses synthetic lube
Old Oct 9, 2007 | 09:54 PM
JimmyDiablo
ORIGINAL: jakebrake
Full synthetic or blend?[X(]
